This allows you to edit the club used, mark a shot out of bounds, or delete a shot.
Open the Garmin Golf app.
Select Activity.
Select a scorecard.
Select View Shot Maps.
Touch a shot to edit.
Make necessary changes on the popup box.
Select Done.
The Garmin Golf™ app allows you to edit the shot location, edit the club used, type of shot, lay of the ball, and remove shots recorded with the Garmin AutoShot™ feature.
When reviewing and editing shots, the type of shot is indicated by the colored dot with the yardage next to it.
Yellow - Tee Shot
White - Drive Shot
Blue - Approach Shot
Select one of the dropdowns below for steps to edit or add shot data.
See Related for more information on the AutoShot feature.
