Open the Garmin Connect app.
Select More (bottom right).
Select Garmin Devices.
Select your Lily watch.
Select Appearance.
Skip to step 6 if you have a Lily® 2 or Lily® 2 Active watch.
Select Widgets (iOS) or Glances (Android).
To remove a widget, select the red minus sign
To add a widget, select the blue plus sign
To change the order of the widgets, hold the three lines to the right of the widget and drag the widget to where you would like it to be.
After you have made any necessary changes, select the back arrow in the top-left corner to save your changes.
Sync your watch.
How Do I Customize the Widgets on My Lily Watch?
The Lily®, Lily® 2, and Lily® 2 Active watches come preloaded with widgets that provide at-a-glance information. To add widgets, remove widgets, or customize the order that they appear on your watch, use your Garmin Connect™ account. Choose your preferred platform below to reveal instructions.
