My Approach S1 is in the Wrong Language
If your Approach® S1 golf watch is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the watch, follow the steps for resetting the device.
Changing the Language
Press and hold OK / Menu.
Press Down 3 times.
Press OK / Menu.
Press OK / Menu 3 times.
Press Down until your language is shown.
Press OK / Menu until the time is shown.
You have now changed the language on your Approach S1 watch.
If you were unable to change the language on your watch using the steps above, the below instructions will guide you through the steps to reset your watch. You will be prompted to select a language after the reset, during initial setup.
