Maximum micro/SD Card Capacity to Be Used with Garmin Chartplotters
NOTES:
• Chartplotter models not listed in this FAQ use proprietary Garmin® Data Cards instead of SD cards. Garmin Data Cards are no longer manufactured or sold by Garmin.
• STRIKER™ fishfinders are not compatible with SD cards or Garmin Data Cards.
Unless stated otherwise2, Garmin chartplotters now support up to 1TB micro/SD cards. The speed class on these cards has an upper limit of UHS Speed Class 3 (U3).
Device series that take microSD cards
ECHOMAP™ chartplotters
GPSMAP® 5x7 chartplotters
GPSMAP® 7x1 chartplotters
GPSMAP® 7x2 chartplotters
GPSMAP® 7x3 chartplotters
GPSMAP® 9x2 chartplotters
GPSMAP® 9x3 chartplotters
GPSMAP® 12x3 chartplotters
GPSMAP® 16x3 chartplotters
GPSMAP® 84xx chartplotters
GPSMAP® 86xx chartplotters
GPSMAP® 90xx chartplotters
GPSMAP® 92xx chartplotters
Devices that take standard SD cards
GPSMAP® 4xx chartplotters
GPSMAP® 5xx chartplotters
GPSMAP® 7xx chartplotters
GPSMAP® 8x0 chartplotters
GPSMAP® 10x0 chartplotters
GPSMA® P 1xx2 chartplotters
GPSMAP® 4xxx chartplotters
GPSMAP® 5xxx chartplotters
GPSMAP® 6xxx chartplotters
GPSMAP® 7xxx chartplotters
GPSMAP® 80xx chartplotters
- GPSMAP® 80xx chartplotters
1 Some older chartplotter models must have updated software to be able to read cards larger than 2 GB, which many maps now require. See Garmin Marine Device Software Updates for instructions.
² Not all devices offer support for 1TB capacity cards. To verify a device's compatibility, refer to New exFAT support on Garmin Marine Devices.
