Sending a MapShare Link From a Montana 710i/760i
Depending on which feature you have enabled on your account, a LiveTrack™ page link or a MapShare™ page link can be sent to friends and family directly from an inReach® device after tracking has been started so that they may follow your progress. If you are using MapShare feature and have set a password for your MapShare page, the password is included automatically when you use the share feature from the website, the device, or the mobile app.
NOTE: Before attempting to send your tracking link, either the LiveTrack or MapShare feature should be enabled and configured in your inReach account. If you attempt to send your tracking link prior to enabling either of these features, the message "You cannot use MapShare until you give consent at explore.garmin.com to post your data online" will be sent to your inReach device and will count as one received message on your monthly invoice. To enable LiveTrack or MapShare, see Setting up LiveTrack for inReach Devices in the Garmin Messenger app or Setting up MapShare in the Garmin Messenger App.
Sending a MapShare Link From a Montana® 710i or 760i Outdoor Handheld
Select
to access the main menu.
Select
Select Tracking.
Select Share With.
Select OK.
Select the To field, then select the contacts you wish to send your MapShare link to:
Select one or more of your contacts from the list, then select
-or-
Select Type Recipients to manually enter contacts, then select
Select the Message field to customize your message.
A default message of I'm starting my trip. Follow along here! will be pre-filled. You can edit or add to this message, if desired. A link to either your LiveTrack page or your MapShare page will be included with the message.
Select Send Message.
