How To Calibrate an Aera's Unresponsive Touchscreen
It is important to calibrate the screen on your aera® portable GPS occasionally in order to ensure that the appropriate letters, numbers, and icons are selected when you touch the screen.
Follow these Steps from the Home Page:
Touch Tools.
Select the Setup icon.
Choose the Display button.
From this page, select Menu located on the right-hand side of the screen.
Touch Calibrate.
The screen will go dark and you will notice a white dot in the lower left-hand corner which will say Press dot above it. To begin calibration, touch the white dot on the screen as close to the center of the dot as possible. Continue to touch the white dots as they appear on your screen until a Calibration complete box appears on your aera, then select Ok. Calibration will complete and the aera will restart itself.
