Mecca Finder
The Mecca Finder application can be used to find your relative position to Mecca on the map. This application also lists daily prayer times used by the Islamic faith.
To Access Mecca Finder:
- Touch Apps on the Where To and View Map screen
- Touch Mecca Finder
Mecca Finder is only Available if Configured for use in the Following Countries:
Albania
Bahrain
Bosnia and Herzegovina
Cyprus
Egypt
Israel
Jordan
Kazakhstan
Kuwait
Lebanon
Macedonia
Morocco
Oman
Qatar
Saudi Arabia
Turkey
United Arab Emirates (UAE)
Yemen
If you are not in one of the countries listed above and Mecca Finder appears on the device, this indicates that the wrong country was selected during the initial device setup. The same is true if you are located in one of the countries listed above and Mecca Finder does not appear. Both can be corrected by changing the locale on the GPS device.
To Add or Remove Mecca Finder:
- Touch Settings on the Where To and View Map screen
- Touch the menu button (three horizontal bars) in the upper left corner of the screen
- Touch Restore
- Select Yes
- To add Mecca Finder, a select country listed above
- To remove Mecca Finder, select a country not listed above.
- Touch OK
- Select your preferred language
- Touch OK
