The Buttons on My Edge 530 No Longer Work When Pressed
When you press a button on the Edge 530 and you do not get a response on the device, make sure that it is not locked up or frozen.
  1. Plug the device into a power source using the USB data cable.
  2. Press and hold the power button (upper left) for a minimum of 10 seconds until the device either powers off or powers on.
If buttons continue to not respond when pressed, you will need to send it back to Garmin for an exchange.  Select the following link to begin the exchange process. Garmin Online Exchange Tool For the Edge 530
IMPORTANT: The Garmin exchange tool is only available in select countries and an exchange fee may apply when submitting a request to replace your device. Refer to the drop-down list in the exchange link for details. Contact your local Garmin Product Support office for assistance if your country is not listed.
