Garmin Bluetooth Device Passkey
A Bluetooth passkey is a numeric code used to establish a pairing between two Bluetooth-enabled devices.
When pairing a Garmin automotive device with a phone via Bluetooth, you may be asked to enter a passkey. Depending on which device you are using, the passkey may also be referred to as a 'PIN' or 'passcode'. If asked to manually enter a passkey on your Garmin device, enter '1234'.
If you are using Garmin software on your phone or computer with a third-party Bluetooth device (such as a Bluetooth receiver), a different passkey may be randomly generated, or in some cases, a passkey may not be needed at all. Consult your device's documentation for more information. If a random passkey is generated, you will need to confirm that the number displayed on the device matches the number displayed on the phone or computer.
View the Appropriate Video Below for Additional Information on Pairing an Automotive Device with a Mobile Phone.
Android:
iOS:
