Setting up LiveTrack for inReach Devices in the Garmin Explore app
A core feature of inReach® satellite communicators is the option of allowing others to follow your trip progress. The following article explains how to do this via a LiveTrack™ page, which is the default method for new inReach subscribers to share their trip progress. Alternatively, if you have enabled a MapShare™ page for your inReach device, or would like to learn more about MapShare, see - Setting up MapShare in the Garmin Explore App.
Use the instructions in this article to enable and configure LiveTrack when using the Garmin Explore™ app with a compatible inReach satellite communicator.
Enabling LiveTrack
Follow the instructions below to enable LiveTrack from the Garmin Explore app (when mobile data or Wi-Fi is available). You can also access this setting by logging in to your account at the Garmin Explore website, then select the MapShare tab.
  1. Open the Garmin Explore app.
  2. Select the profile icon in the top left.
  3. Select MapShare.
    • NOTE: If LiveTrack is listed here rather than MapShare, this means LiveTrack is already enabled.
  4. Select Switch to LiveTrack.
    Messenger app Switch to LiveTrack
  5. Select Agree for the LiveTrack Location Data Agreement.
After agreeing to the LiveTrack Location Data Agreement, you will be presented with options to edit your LiveTrack URL, adjust your privacy settings, or switch back to MapShare:
LiveTrack Explore App Settings
You can get back to these settings at any time by selecting the profile icon in the top left of the Garmin Explore app, then select LiveTrack from the list of settings. Additional LiveTrack settings will be available once you have entered recipients and set up your LiveTrack profile.
Set Up or Edit Your LiveTrack Profile URL
Your LiveTrack profile is a page where viewers can see your LiveTrack sessions. After enabling LiveTrack, you can set up or edit your LiveTrack profile URL.
  3. Select LiveTrack.
  4. Select Pencil next to your LiveTrack profile URL.
  5. Tap on the field for your URL to customize it.
    Your custom URL must be between 3 and 64 characters in length and contain only letters (a-z), numbers (0-9), underscores (_), or dashes (-).
    Create LiveTrack URL Messenger
  6. Enter a custom URL, then select Save.
Example LiveTrack Profile
LiveTrack Profile Page for inReach
Share a Link to Your LiveTrack Page
After enabling LiveTrack, you can send a message with a link to your LiveTrack page when you start tracking.
  1. Ensure your paired inReach device is powered on, then open the Garmin Explore app.
  2. Select Watch and Handheld Icon Devices.
  3. Select Tracking under inReach Features.
    Example of inReach Mini 2 with inReach Features
  4. Start inReach tracking by touching the triangle in the orange circle.
    Start Tracking Icon
  5. Select an option:
    • inReach Message Icon inReach Message: Opens the inReach message window, allowing you to select who to send a message to with your LiveTrack™ URL link.
      • NOTE: The LiveTrack URL link will not be displayed in the message window, but will automatically be included with the message.
    • Share Icon Share (Requires Data Connection): Opens a list of options to share your LiveTrack URL with other apps on your paired mobile device (email, other messaging apps, etc.). These options require your mobile device to have a data connection.
Session Privacy Settings
After setting up your LiveTrack profile URL, you will have the option to adjust the privacy settings for new or past LiveTrack sessions.
Privacy Settings for New Sessions
  4. Select the drop down menu below Saved Session Privacy, then select Only Me or Everyone.
After selecting Only Me, viewers of your LiveTrack profile URL will not see any new LiveTrack sessions and they will only be visible to you. Your LiveTrack recipients will still receive a link of your active LiveTrack location through email and/or text to view the session while it is in progress.
After selecting Everyone, viewers of your LiveTrack profile URL will see all new LiveTrack sessions on your profile.
Privacy Settings for Active Sessions
  4. Select the drop down menu below Active Session Privacy, then select Only Me or Everyone.
If set to Only Me, viewers of your LiveTrack profile URL will not see your current LiveTrack location. Your LiveTrack recipients will still receive a link of your active LiveTrack location through email and/or text to view the session while it is in progress.
If set to Everyone, viewers of your LiveTrack profile URL will see a link to your current LiveTrack location:
Active LiveTrack Session on Profile
Privacy Settings for Past Sessions
Privacy settings for past sessions cannot be changed through the Garmin Explore app, but can be changed on the Garmin Explore website.
  1. Log in to your account at explore.garmin.com
  2. Select LIVETRACK.
    NOTE
    : On mobile browsers, select Two Horizontal Lines Icon in the top left, then LIVETRACK.
  3. Select Manage Privacy Settings or Delete Account.
  4. Select Update Past Sessions.
  5. Select Only Me or Everyone.
  6. Select UPDATE.
  7. Select Continue when prompted to change the privacy of all past sessions.
After selecting Only Me, all past LiveTrack sessions will be visible only to you.
After selecting Everyone, viewers of your LiveTrack profile URL will see all past LiveTrack sessions on your profile.
Privacy Settings for Individual Sessions
You can change the privacy of any individual session by editing the session from your LiveTrack profile. Select the lock icon next to an activity, then select Locked Only Me or Unlocked Everyone:
LiveTrack Activity Privacy Settings
View LiveTrack Consent
After enabling LiveTrack, you can go back and view the LiveTrack consent agreement and opt out if you decide to. Opting out will disable LiveTrack.
  4. Select View LiveTrack Consent.
  5. Select Opt Out or Cancel.
    Messenger App LiveTrack Consent
Changing Map Unit Settings for LiveTrack
While viewing someone's LiveTrack session, the viewer can select 3 Lines Menu Symbol in the top right of the page, then select the drop down menu for the map units:
LiveTrack Map Units Setting
All track points sent from your inReach device are automatically sent to your LiveTrack page. For steps on starting and stopping tracking, see - Tracking With the Garmin Explore App.
Related
