Edit User Settings and Heart Rate Zones in Garmin Connect
NOTE: Device settings cannot be adjusted through Garmin Connect web if the watch supports Real Time Settings. For more details, see - Real Time Settings in the Garmin Connect App.
User Settings and Heart Rate Zones can be edited in the Garmin Connect™ program and sent to compatible fitness device by syncing with Garmin Express™ software.
  1. From a web browser sign into your Garmin Connect account.
  2. Select (top right).
  3. Select Device Settings under the device you wish to edit.
  4. Select User Settings.
  5. Update information as needed.
  6. Select Save Settings.
  7. Sync the device through Garmin Express program.
Garmin Express program will open, and the user settings will transfer to your device once the sync is complete.
Related
