Identifying Power Plugs for HD and MHD Amplifiers
There are two different power plugs for HD & MHD Amplifiers.
HD PLUG PWR (#98282) (left) HD PLUG PWR2 (#98283) (right)
HD-PWRPLUG2-4AWG-RP (#48282) (left)       HD-PWRPLUG2-2AWG-RP (#48284) (right)
Amplifier Model (SKU)Valid Serial NumbersPower Plug Used
HD600/4 (#98221)                 AllHD-PWRPLUG2-4AWG-RP (#48282)
HD900/5 (#98223)AllHD-PWRPLUG2-4AWG-RP (#48282)
HD750/1 (#98220)Up to SN: 108034000001HD-PWRPLUG2-4AWG-RP (#48282)
MHD600/4 (#98224)AllHD-PWRPLUG2-4AWG-RP (#48282)
MHD900/5 (#98226)AllHD-PWRPLUG2-4AWG-RP (#48282)
MHD750/1 (#98225)Up to SN: 153034000001HD-PWRPLUG2-4AWG-RP (#48282)
HD750/1 (#98220)SN: 108034000001 and upHD-PWRPLUG2-2AWG-RP (#48284)
HD1200/1 (#98250)AllHD-PWRPLUG2-2AWG-RP (#48284)
MHD750/1 (#98225)SN: 153034000001 and upHD-PWRPLUG2-2AWG-RP (#48284)
Uses HD Plug PWR (98282)
Uses HD-PWRPLUG2-4AWG-RP (#48282)
The way the older HD750/1 and MHD750/1 can be identified, is the plastic trim around the area the plug connects to the amplifier. In the image above, note the screws on either side of the opening.
Uses HD Plug PWR2 (98283)
Uses HD-PWRPLUG2-2AWG-RP (#48284)
You can identify the newer HD750/1 and MHD750/1 by the plastic trim around the area the plug connects to the amplifier. In the image above, note the larger overall size and the lack of screws on either side of the opening.
Related
