How to Add, Change, or Customize Ballistic Profile Data Fields on a Foretrex 901 Ballistic Edition
The following will cover how to add, change, and customize the ballistic profile data fields on a Foretrex® 901 Ballistic Edition wrist-mounted GPS navigator. You can also customize a ballistic profile through the Applied Ballistics Quantum™ app on your smartphone or tablet.
Adding a Profile
- From the Applied Ballistics page, press ENTER.
- Select PROFILE > PROFILE > + PROFILE.
- Select an option:
- To customize the bullet properties, select BULLET PROPERTIES.
- To customize the gun properties, select GUN PROPERTIES.
- To change the units of measure for the output fields, select OUTPUT UNITS.
Selecting a Different Profile
- Select PROFILE > PROFILE.
- Select the profile you want to use.
- Select CHANGE PROFILE.
Customizing the Profile Data Screen
- During an Applied Ballistics activity, press DOWN to scroll to the profile data screen.
- Press ENTER.
- Select CHANGE FIELDS.
- Press DOWN or UP to scroll to a field.
- Press ENTER to change the field.
- Press PAGE to save your changes.
Deleting a Profile
- Select the profile you want to delete.
- Select DELETE PROFILE.
