Adjusting the Pin Size for the Xero Bow Sights
The pin size cannot be adjusted. The size of the pin for Xero® bow sights does not change size. It will always remain at a size of .007".
Raising the brightness does give the illusion of a larger pin. Higher brightness will simply create a halo effect around the pin that can make it appear larger. This halo effect can cause the appearance of pins merging into one another at higher values if the distance between pins is close enough in a fixed pin stack.
Lowering the brightness value will lessen this halo effect and give the illusion of the pin decreasing in size.
For more steps on adjusting the brightness, see Adjusting Brightness in the owner's manual.
