Deleting Data and Messages From the Garmin Explore Website
The Garmin Explore™ website allows you to delete unwanted data and messages from your account.
IMPORTANT: Any data deleted from a Garmin Explore website account is permanently deleted and cannot be recovered. Only delete data that is unwanted and unneeded.
Deleting Data From the Library
Deleting Tracks
  1. Log in to the Garmin Explore website.
  2. Select MAP.
    NOTE: On mobile browsers, select Two Horizontal Lines Icon in the top left, then MAP.
  3. Select Tracks.
    Red Arrow Pointing to Tracks Catagory
  4. Select the Tracks tab.
    Red Arrow Pointing to Tracks Tab
  5. Select the track to delete.
    TIP: Use CTRL+Click (Windows), Command+Click (Mac), or Shift+Click (Windows/Mac) to select multiple items.
    Red Arrow Pointing to a Track
  6. Select Trash Can Iconin the track summary.
    Red Arrow Pointing to Trash Can
  7. Select Delete to confirm.
    Red Arrow Pointing to Delete
NOTE: If the track you are attempting to delete is also listed in a Collection, the track will also be deleted from that collection.
The selected track will now be deleted from the Library.
Deleting Waypoints
  2. Select MAP.
  3. Select Waypoints.
    Red Arrow Pointing to Waypoints Catagory
  4. Select the Waypoints tab.
  5. Select a waypoint to delete.
    Red Arrow Pointing to a Waypoint
  6. Select Trash Can Icon next to the waypoint(s) to delete.
The selected waypoint(s) will now be deleted from the Library.
Deleting Routes
  2. Select MAP.
  3. Select Routes.
  4. Select the Routes tab.
  5. Select a route to delete.
  6. Select Trash Can Icon next to the route(s) to delete.
The selected route(s) will now be deleted from the Library.
Deleting Courses
  2. Select MAP.
  3. Select Courses.
    Red Arrow Pointing to Courses
  4. Select the Courses tab.
  5. Select a course to delete.
    Red Arrow Pointing to a Selected Course
The selected course(s) will now be deleted from the Library.
Deleting Activies
  2. Select MAP. NOTE: On mobile browsers, select Two Horizontal Lines Icon in the top left, then MAP.
  3. Select Activities.
    Red Arrow Pointing to Activities
  4. Select the Activities tab.
    Red Arrow Pointing to Activities Icon
  5. Select an activity to delete. TIP: Use CTRL+Click (Windows), Command+Click (Mac), or Shift+Click (Windows/Mac) to select multiple items.
    Red Arrow Pointing to a Selected Activity
  6. Select Trash Can Icon next to the activity or activities to delete.
The selected Activity will now be deleted from the Library.
Deleting Unorganized
The Unorganized category is where new data that has not been assigned to a collection appears.
  3. Select Unorganized.
    Red Arrow Pointing to Unorganized Catagory
  4. Select the tab for the data you wish to delete.
    Red Box Around Tab Options
  5. Select items to delete. TIP: Use the top box to select all items in the list, or individually select each box next to an item.
    Red Arrow Pointing to Boxes to Check
  6. Select Delete.
The selected data will now be deleted from the Library.
Deleting Messages From the Inbox
NOTE: These steps are only applicable when using devices with inReach® satellite communicator messaging capabilities.
Deleting a Single Message
  2. Select INBOX.
    NOTE: On mobile browsers, select Two Horizontal Lines Icon in the top left, then INBOX.
  3. Under People, select the contact thread to delete messages from.
    Red Arrow Pointing to MapShare
  4. Select Trash Can Icon next to the message to be deleted.
  5. Select Delete to confirm.
The selected message will now be deleted.
Deleting a Conversation Thread
  2. Select INBOX.
  4. Select Trash Can Icon to remove the entire conversation thread for that person.
The selected conversation thread will now be deleted.
Deleted items may reappear after syncing your Earthmate® app compatible inReach® satellite communicator. If this happens, see Deleted Data Reappearing on the Map of the Garmin Explore Website.
NOTE: Changes made to collections sync settings after data has been synced to a device will not delete that original data from the device after doing another sync. For steps on deleting data from the device, see your device owner's manual.
