How Do I Manually Upload an Activity I Recorded to the Garmin Dive App?
If a recorded dive from your dive computer did not sync into the Garmin Dive™ app, you can manually import the activity into the Garmin Connect™ website, which will then send the dive information to your Garmin Dive app automatically. Instructions to manually upload the activity are below. You will need the USB charging/data cable that came with your dive computer and a personal computer with a USB port in order to manually upload the activity.
Manually Uploading Activities
NOTE: Mac computers do not allow native access to Media Transfer Protocol (MTP) devices. Therefore only Descent™ G1 series watches and Descent™ Mk1 watches are accessible from a Mac computer.
  1. Connect your dive computer to a computer using your charging/data cable.
  2. Sign in to your Garmin Connect account with the same sign-in credentials used in the Garmin Dive app.
  3. Select Cloud Icon With Up Arrow in the top right corner of the page.
  4. Select Import Data.
  5. Select Browse.
  6. Locate and select an activity file. To locate the activity files on the watch, select your computer's operating system below:
    Windows
    With the dive computer connected to your computer:
    1. Click Windows key + E
    2. Click This PC (Windows 10 only)
    3. Double-click the Garmin watch drive
    4. Double-click the Garmin folder
    5. Double-click the Activities folder and select an activity to import
      • Activity (FIT) files will typically be titled in the following format:
        Year, Month, Day, Hour, Minute, Second
    Mac
    NOTE: These steps will only work for the Descent G1 series watches or Descent Mk1 watches.
    1. Open Finder.
    2. Click Go in the menu bar.
    3. Click Computer.
    4. Double-click the Garmin drive.
      Mac Device Drive in Finder
    5. Double-click the Garmin folder.
    6. Double-click the Activities folder and select an activity to import.
  7. Select Import Data.
Once the activities are uploaded, they can be viewed in the Garmin Connect portal and Garmin Dive app.
Related
