Receiving an SD Memory Card When Ordering a Garmin microSD Memory Card
In order to eliminate multiple packages for SD and microSD memory cards, all memory cards are distributed by Garmin as microSD cards in an SD card adapter. This allows the cards to be used on a wider range of devices, regardless of whether the device uses a standard SD card or a microSD card. If the SD card doesn't fit in your device, you may need to use the microSD card instead.
To use the microSD card, simply slide it out of the SD adapter. You can do this by pulling gently on the lip on the front of the card. See the example below:
For instructions on inserting the microSD card into the device, see the example below or refer to the device's owner's manual.
