Activating the Beacon Light on a Dog Tracking Collar
Many Garmin dog tracking collars have LED beacon lights that help the user see the dogs in lower light conditions from afar. The steps below outline how to activate the collar LED beacon light.
Activating the collar beacon lights:
Select your dog tracking device below to view steps
Alpha® XL Navigator
Ensure the collar is turned on and tracking.
From the Main Menu select Pro View or Dog List shortcut.
Select the desired collar.
Select Blink Mode. Select from list the desired setting (Continuous, Blink Slow, Blink Fast, Off).
Select back arrow
Select Beacon Color to change the beacon light color. NOTE: Color change only works with Alpha T 20/Alpha TT 25 collars
Alpha® 200 Plus, Alpha® 300, and Alpha® 300i Handhelds
From the home screen, select Dog List.
Select Adjust Collar Light.
Select Change Color to change the beacon light color. NOTE: Color change only works with Alpha T 20/Alpha TT 25 collars.
Alpha® 200 & Alpha® 200i Handhelds
Alpha® 100 Handheld
Select Show Info.
Press menu.
Alpha® 10 Handheld
Select Edit.
Select Collar Light
Select the desired setting (Continuous, Blink Slow, Blink Fast, Off).
Select Change Color to change the beacon light color NOTE: Color change only works with Alpha T20/TT25 collars.
