Transmitting NMEA 2000 Data Wirelessly to a Quatix
The Quatix* has the ability to connect to a NMEA 2000 network wirelessly and display data preset on the network.
Required Equipment
A GNT 10 is required to be installed on the NMEA 2000 network in order to transmit data to the watch.
Available Data Fields
  • AWA (Apparent Wind Angle) - The wind angle measured with respect to the bow of the vessel.
  • A WIND CHL (Apparent Wind Chill) - The temperature of the wind chill relative to the boat.
  • AWS (Apparent Wind Speed)  - The measured speed of the wind.
  • CARDWIND (Cardinal Wind Direction) The true wind direction described in cardinal directions.
  • DEPTH - The depth of the water.
  • DRIFT - The speed of the current.
  • GWS (Ground Wind Direction) - The direction of the wind relative to the land, reference from the north.
  • G WIND CHL (Ground Wind Chill) - The temperature of the wind chill relative to the land.
  • GWS (Ground Wind Speed) - The speed of the wind relative to the ground. If there are no current and no leeway, the ground wind speed is equivalent to the true wind speed.
  • OPP TACK (Opposite tack heading) - The opposite tack direction of the vessel based on the current tack direction.
  • SET - The direction of the current referenced from the north.
  • STW (Speed Through Water) - The speed of the boat relative to the water.
  • TWD (True Wind Direction ) - The true direction of the wind relative to North.
  • TWS (True Wind Speed) - The true speed of the wind relative to the vessel.
  • VMG TO WND (Velocity Made Good to Wind) - The speed at which you are making progress into the wind.
  • WATER TEMP (Water Temperature) - The temperature of the water.
*This article does not apply to the Quatix 3 or Quatix 5
