Sharing Routes/Trips from a Camper/RV 890 or Camper/RV 1090
You can share a route/trip you have created with other Garmin users in two ways: through the Garmin Drive App or with a memory card.
To Share a Route/Trip Using the Garmin Drive App
1. Touch Trip Planner
2. Touch Saved Trips
3. Touch the wrench in the top left corner
4. Touch Share
5. Touch Garmin Drive
6. Select the trips you want to share
7. Touch Done
8. Touch OK
9. Open the Garmin Drive App on your phone
10. Touch Share
11. Follow the on-screen instructions to share the .gpx files
12. The receiving Garmin user can then open the file with the Garmin Drive App
13. Touch Send in the Garmin Drive App
The trip will now be found in Trip Planner on the receiving device.
To Share a Waypoint/Saved Location With the Garmin Drive App
1. Touch Where To?
2. Touch Saved
3. Touch the menu button in the top left corner
4. Touch Share
6. Select the waypoints you want to share
7. Touch Done
8. Touch OK
10. Touch Share
11. Follow the on-screen instructions to share the .gpx files via email
The waypoint will now be found in your Saved places on the receiving device.
To Share a Trip Using a Memory Card
1. Insert a compatible microSD card into the memory card slot on your Camper/RV 890
2. Touch Trip Planner
3. Touch Saved Trips
4. Touch the wrench in the top left corner
5. Touch Share
6. Touch Memory Card
7. Select the trips you want to share
8. Select Done
To Share a Route/Waypoint Using a Memory Card
2. Touch Where To?
3. Touch Saved
4. Touch the menu button in the top left corner
5. Touch Share
7. Select the waypoints you want to share
8. Touch Done
