Discontinued Garmin Marine Device Master Reset List
Use caution when performing a master-reset on a discontinued device. The devices on this list are no longer repaired and if the master reset damages the unit it cannot be replaced or repaired. If possible, back up user data, if the required equipment is not available (devices that utilize Garmin Data cards) user data will be lost.
echoMAP™ 4x chartplotters | echoMAP™ 5x chartplotters | echoMAP™ 7x chartplotters (non-touchscreen) | echoMAP™ 9x chartplotters
To perform a master reset:
Turn the chartplotter Off
Hold the Home and Power buttons until a message appears asking to delete or erase all user settings?
Select Yes
The chartplotter will now reset.
echoMAP™ 70s series (touchscreen)
Hold the Power button until the Garmin logo appears
Hold the upper-left corner of the display until Delete all user settings? appears
Select Yes
Discontinued GPSMAP® Series
GPSMAP® 16x chartplotters | GPSMAP® 17x chartplotters | GPSMAP® 17xC chartplotters | GPSMAP® 182 chartplotters | GPSMAP® 182C chartplotters | GPSMAP® 188 chartplotters | GPSMAP® 188C chartplotters | GPSMAP® 192 chartplotters | GPSMAP® 198C chartplotters | GPSMAP® 232 chartplotters | GPSMAP® 238 chartplotters | GPSMAP® 276C chartplotters | GPSMAP® 29x chartplotters | GPSMAP® 2xxx chartplotters | GPSMAP® 376C chartplotters | GPSMAP® 378 chartplotters | GPSMAP® 39x chartplotters | GPSMAP® 3xxx chartplotters | GPSMAP® 478 chartplotters | GPSMAP® 49x chartplotters
Hold the Quit and Power buttons until the message, Do you really want to erase all user data? appears
Select Yes
GPSMAP® 180 chartplotters |GPSMAP® 185 chartplotters | GPSMAP® 230 chartplotters |GPSMAP® 235 chartplotters
Hold the Quit and Power buttons until the chartplotter finishes booting
The chartplotter will not give a warning that a master reset is about to take place
GPSMAP® 21x chartplotters | GPSMAP® 2x chartplotters
Hold the Data and Power buttons until the chartplotter finishes booting
GPSMAP® 4xx chartplotters |GPSMAP® 5xx chartplotters |GPSMAP® 8xx chartplotters | GPSMAP® 1xxx chartplotters | GPSMAP® 4xxx chartplotters |GPSMAP® 6xxx series
Hold the Home and Power buttons until a message appears to erase or delete all user settings?
Select Yes
GPSMAP® 7x0 chartplotters | GPSMAP® 5xxx chartplotters | GPSMAP® 70xx chartplotters | GPSMAP® 72xx chartplotters
Turn the chartplotter On
From the home screen, select Configure
Select System
Select System Information
Select Factory Settings
Select Yes
GPSMAP® 7x1 chartplotters | GPSMAP® 7x1xs chartplotters
Hold the upper left corner of the touchscreen until the message Delete all user settings? appears
Select Yes
GPSMAP® 7x2 chartplotters | GPSMAP® 7x2xs chartplotters | GPSMAP® 9x2xs chartplotters | GPSMAP® 9x2 chartplotters
Hold the Power Button as soon as the Garmin logo appears release power button
When "I agree" appears quickly press and hold the top-left corner of the display until Delete All User Settings? appears
Select Yes
