Changing preferred sources while using a GCV 10 and a second ClearVu transducer
If you are using a directly connected ClearVu transducer along with a GCV 10, your device will automatically default to show the returns from the GCV 10's transducer. If you would prefer to see the returns from the directly connected transducer, follow these instructions:
  1. Home
  2. Select Settings
  3. Select Communications
  4. Select Preferred Sources
You will be able to change the preferred source of ClearVu here.
