Using the Xero S1 with Multiple Gun Profiles
If you are a coach or want to use the Xero® S1 trapshooting trainer for a group you can use the gun profiles option to create up to 10 different gun profiles.
A few things to keep in mind:
- In Trap Mode only 1 gun profile can be used per round
- Each gun profile will have to complete a round before the next gun profile can be used
- In Upland Mode only the unit owner's scorecard is saved. When setting up the round you will indicate which shooter is the owner of the Xero S1 trainer
- If each shooter needs to record their information to the unit they will need to shoot each round individually
- The Xero S1 can only pair with one smartphone with a Xero S App account at a time
- All recorded scorecards will load to a single Xero S App account
- You can log into a Xero S App account on multiple mobile devices to see scorecards from a single Xero S1, but only the primary paired mobile device is used to pull scorecards from the device and get them into the Xero S App
- With the updated version of the Xero S App the name on the gun profile is saved to scorecard. The gun profile can be filtered in the App.
