Creating Routes Using Custom Points of Interest on Automotive Devices with Trip Planner
Trip Planner is an application that is used for creating routes on certain Garmin automotive devices. These devices will also support the use of loading Custom Points of Interest (POIs) that are downloaded from the Internet.
To Create a Custom Route with a Saved Custom POI:
- Touch Apps or
- For the dēzl™ 560, Touch Where to? or Tools
- Touch Trip Planner
- You may have to touch Navigation or dēzl™ first on some devices
- Touch the Menu button (three horizontal bars)
- Skip this step on some devices
- Touch New Trip, Create Trip, or the + button (add new route)
- Touch Select Start Location
- Touch Categories
- Touch Custom POIs
- Touch the desired Custom POI
- Touch Select
- On some devices, touch the info circle, then touch Select
- Repeat steps 3-9 as necessary to create the route
- Touch Next
- Enter a name for the route
- Touch Done
The custom route has now been created.
For information on loading Custom POIs to a device, see Installing Additional Points of Interest to an Automotive Device.
