Connect IQ Store App: How to Uninstall App Content
In order to uninstall your Connect IQ™ apps or other content you will need to have the Garmin® watch paired and connected to the Garmin Connect™ app. For help connecting please see, Garmin Connect App Bluetooth Troubleshooting.
  1. Open the Connect IQ™ Store app.
  2. Select Device (bottom right).
    • If you need to change devices, select Three Dots Icon (top right) and select the correct Garmin device.
  3. Installed Connect IQ Content will be found under these categories: (If you are missing a category then it is not supported on your device).
    • My Watch Faces - Here you will find your installed Face It® watch faces and Connect IQ watch faces.
    • My Device Apps - Here you will find your installed Widget Glances or Activity Profiles.
    • My Data Fields - Here you will find your installed Activity Data Fields.
    • My Music - Here you will find your installed Music Apps.
  4. Select the app you wish to remove.
  5. Select Three Dots Icon (top right).
  6. Select Uninstall.
  7. Sync your device.
The Connect IQ app content will be removed from your device after your next successful sync.
Related
