Viewing the Distance Left on an Active Route
You may view the remaining distance on your active route by viewing the Trip Computer. To access the Trip Computer, touch the data field that displays your current speed on the map screen.
The distance remaining on the route is displayed to the right of the speedometer.
To view the Trip Computer or Trip Data:
- Enter a destination and touch Go!
- After the route is calculated, the device will display the Map Page
- Touch the menu button (three horizontal lines)
- Touch Trip Computer or Trip Data
The total distance remaining on the journey will be displayed directly below the speedometer in the Arrive In field. If you do not see this option, it will need to be enabled.
Your device also has the option to add the Trip Computer as a map button.
To add the Trip Computer map button:
- Touch Settings
- Touch Map & Vehicle
- Touch Map Buttons
- Touch the map button to remove
- The maximum number of buttons allowed is three for this device.
- Touch an empty button (displays as a +)
- Touch Save once the desired buttons have been set
- Touch Cancel to discard changes and use the current map buttons
- Touch Reset to Defaults to return to the default map buttons
The map buttons are now set to your preference.
