(2024) Service Advisory 24023 Rev B: Hangar/Facility Wi-Fi Router Firewall Domain and Protocol Settings
REVISION B:
Clarified Router Firewall Settings
PRODUCTS AFFECTED:
GDL 60 products using PLANESYNC™ Connected Aircraft Management and Connext® Connected Cockpit that are connected to a hangar/facility Wi-Fi are affected.
ISSUE:
Database download errors, registration failures, etc., may appear if the hangar/facility Wi-Fi router firewall domain and protocol settings are not set properly.
PLANESYNC and Connext require specific hangar/facility Wi-Fi router firewall domain and protocol settings in order to allow the required network traffic. Refer to the settings listed in the ACTION section.
ACTION:
The hangar/facility Wi-Fi router firewall domain and protocol settings will need to be changed per Table 1 and Table 2.
NOTE
The settings listed in Table 1 and Table 2 are not internal GDL 60 settings. Refer to the configuration guidance provided by the applicable hangar/facility Wi-Fi router manufacturer.
Table 1. Required Firewall Domain Settings
Domain | Ports |
Avcloud-gateway.garmin.com | 443 |
omt.garmin.com | 443 |
download.garmin.com | 80, 443 |
devicesources.garmin.com | 443 |
device-auth.security.services.garmin.com | 443 |
dlms.garmin.com | 443 |
Table 2. Required Firewall Protocol Settings
Protocol | Ports |
Domain name service (DNS) | 53 |
TCP | 80, 443 |
