My Fenix 5 Series Watch Battery Drains Quickly, Freezes, Reboots or Won't Power On
If a Garmin Outdoor watch is draining battery quickly, freezing, rebooting, or will not power on, there are a number of troubleshooting steps that can be performed that can help restore your watch to working order.
Frozen
- Hold the Power button for 30 seconds to perform a soft reset. Data is not erased with a soft reset.
- For information on where the Power button is located, see your Garmin owner's manual.
- Try plugging the watch into a power source.
- Plug the watch into a power source and attempt a soft reset.
Will Not Power On
- Hold the Power button for up to 30 seconds to force the watch to power on. Release the Power button if the watch starts to come on.
- Plug the watch into a power source and hold the Power button for 30 seconds or until it starts to power on, whichever occurs first.
- Try these charging steps:
- Allow charging for 2 hours
- Remove from the power source for 5-10 minutes
- Plug the watch back into the power source
- Allow charging for another 2 hours
- Hold the Power button for 30 seconds or until the watch powers on, whichever occurs first
Factory Reset
NOTE: Resetting a watch will disconnect it from the Connect app but not Bluetooth settings, see How do I Remove a Device from the Garmin Connect App? for steps on how to remove it.
- Delete potentially corrupt files from the unit (to prevent the loss of user data sync with Garmin Express):
- Open the device as a storage drive on the computer1
- Open the Garmin folder
- Delete the GPX and Activity folders if present
- Make sure to empty the Trash if on a Mac
- If the unit is still not functioning properly, attempt to perform a master reset (or factory reset) on the device. Refer to your Owner's Manual for steps on resetting the watch.
1 The D2 Delta Series, Enduro, fenix 5 Plus Series, fenix 6 Series, MARQ Collection, and tactix Delta will not mount as a drive on a Mac computer, and you will not be able to access the drive to remove files.
