The Button on My Varia RTL515 Is Stuck or Not Responding
Cycling over time can cause a build up of debris which may result in the button not functioning properly. To loosen dirt and grime from the button, please perform the following steps:.
Ensure the USB weather cap is in place.
Place the Varia under streaming warm water for about 10 seconds.
Remove it from the running water and press the button repeatedly a few times.
Rinse it again for about 10 seconds.
When the unit appears to be clean, remove it from the water and test the button to verify that it works correctly.
The Button Is Still Stuck After Cleaning
If the button on your Varia RTL515 Radar is still not working after cleaning the device will need to be replaced by Garmin. You can request an exchange using the following tool: Garmin's Online Exchange for the Varia RTL515 Radar
IMPORTANT: The Garmin exchange tool is only available in select countries and an exchange fee may apply when submitting a request to replace your device. Refer to the drop-down list in the exchange link for details. Contact your local Garmin Product Support office for assistance if your country is not listed.
