Setting an Abnormal Heart Rate Alert in Garmin Connect
Compatible Garmin watches can notify you when your heart rate goes above or below a specified level. If you are inactive for a minimum of 10 minutes, and your heart rate goes above or below your set threshold, you will get an alert on your watch.
IMPORTANT: Garmin watches are not medical devices. Heart rate data is not intended to be used for medical purposes, nor is it intended to diagnose, treat, cure, or prevent any disease or condition.
To set an Abnormal Heart Rate Alert via your Garmin Connect™ account, choose one of the options below.
Garmin Connect App
  1. Open the Garmin Connect app on your phone.
  2. Select More (bottom right).
  3. Select Garmin Devices.
  4. Select the watch you want the alert on.
  5. Select Sounds & Alerts.
  6. Select Abnormal Heart Rate Alert.
  7. Turn on the desired alerts and set the values.
Garmin Connect Web
  1. From a web browser, sign into your Garmin Connect account.
  2. Select black watch icon in the upper right corner of the web page.
  3. Select Device Settings under the watch you want to add the alert to.
  4. Under Sounds & Alerts turn on the alerts you want and set the thresholds.
    The Abnormal Heart Rate Alerts settings for a watch in Garmin Connect web
  5. Select Save Settings.
  6. Sync your watch with the Garmin Express™ software or your phone.
Related
