Pairing a Forerunner 25 with the Garmin Connect App
When paired with your device, the Garmin Connect App can wirelessly upload and share fitness data with the Garmin Connect website as well as send smart notifications from your smartphone to your wrist.
To pair your Forerunner 25 choose your phone's platform:
iOS
    1. Place the iOS device within 10 ft. (3 m) of the Forerunner 25
    2. Ensure that Bluetooth is enabled on the iOS device (see iOS device manual for details)
    3. On the iOS device, open the Garmin Connect App
    4. Select the More icon in the lower right corner
    5. Select Garmin Devices
    6. Select Add Device
    7. Select Browse all compatible devices
    8. Select  Forerunner
    9. Select  Forerunner 25
    10. Complete the Personal Information if requested. This allows the Forerunner 25 to assign personalized goals and learn your activity level.
    11. Select  Next
    12. On the Forerunner 25, press the down arrow button to locate Settings
    13. Select Settings
    14. Select Bluetooth
    15. Select Pair Smartphone
    16. Select Start in the Garmin Connect App
    17. Select Yes after verifying the passkeys match
    18. Select your choice for Activity Tracking
    19. Select Done
You have now successfully paired the Garmin Connect App with your Forerunner 25, and the device can now sync.
Android
    1. Place the Android device within 10 ft. (3 m) of the Forerunner 25
    2. Ensure that Bluetooth is enabled on the Android device (see Android device manual for details)
    3. On the Android device, open the Garmin Connect App
    4. Select the Menu button (≡) located in the upper-left corner
    10. On the Forerunner 25, press the down arrow button to locate Settings
    11. Select Settings
    12. Select Bluetooth
    13. Select Pair Smartphone
    14. Select Search for Device
    15. Select Yes after verifying the passkeys match
    16. Select your choice for Activity Tracking, if prompted
    17. Select OK when the devices are paired
