How the Routing Preferences Work on a Honda Navigation System
The Honda Navigation System provides you with multiple route preference options.
To Change your Routing Preference:
Access the Navigation or Map screen
Touch
or
Touch Settings from the main navigation screen
Touch Navigation
Touch Calculation Mode
From the next screen, you will be able to choose your routing preference.
An Explanation of These Route Preferences can be Found Below:
- Shorter Distance: Creates a route that is a shorter driving distance between two points
- Faster Time: Utilizes information including posted speed limits, road types, and driving distance to create a route that is faster
- Faster Time may often have a longer distance, but offers a faster arrival time over the Shorter Distance option
- Less Fuel: The device uses distance and posted speed limits to calculate a route that will use less fuel
