Automatic Volume
Automatic Volume uses ambient noise in the car to determine and set the appropriate volume level for the device's audio.
To Enable or Disable Automatic Volume:
- Touch Volume
- Touch Automatic Volume to place or remove the check mark
- Touch the
back button to return to the main menu
The device will now automatically adjust the volume as needed based on ambient noise. Repeat the above steps to disable Automatic Volume and adjust volume levels manually.
