Displaying Taxiway Identifiers on my GPSMAP 695/696 while using the SafeTaxi Database
While viewing the SafeTaxi® diagrams on the GPSMAP® 695/696 handheld navigator, the runway and taxiway position signs can be displayed at the same time. Follow the steps below to ensure the taxiway position signs are displayed on the diagram.
From the Map Page:
  1. Press the Menu button
  2. Select Set Up Map
  3. Use the FMS joystick and scroll to the right along the top until the Miscellaneous page is displayed.
  4. Using the FMS joystick again, scroll downward within the Miscellaneous page until Other Areas is highlighted.
  5. Ensure that Miscellaneous is set to Auto or a specific zoom-level in nautical miles.
    • If this setting is Off, the taxiway identifiers will not display on the SafeTaxi diagram.
When the SafeTaxi diagram is displayed on the GPSMAP 695/696, the taxiway identifiers should now appear along with the runway numbers on the airport diagram page.
Related
