MediaMaster® iPhone Playback
An iPhone® may be connected to the USB port using an appropriate Lightning to USB cable (not included).
Once connected, press the SOURCE button and select USB from the "SOURCE: Select" menu to access the connected device with the following controls:
Pressing BACK/MENU will let you search the iPhone with VOL/SEL. Turn the rotary knob and press it in to make a selection. Users have the option to search by Playlists, Artists, Songs, Albums, Genres and Composers.
Properly secure the connected device before driving to prevent damage from dropping or sudden acceleration/braking.
Control, functionality and display may vary depending on the model and version of iPhone® connected.
When connected via the USB port, make sure to un-pair or disable the Bluetooth® connection to avoid possible playback conflicts.
If you experience abnormal performance during operation, disconnect the iPhone® and check its condition. Restart your iPhone® if performance does not improve.
“Made for iPhone” means that an electronic accessory has been designed to connect specifically to an iPhone® and has been certified by the developer to meet Apple performance standards. Apple is not responsible for the operation of this device or its compliance with safety and regulatory standards. Please note that the use of this accessory with an iPhone® may affect wireless performance.
