Deleting Track Points
- From the Main menu, select History.
- Select the desired day.
- Select the desired point to delete.
- Select More....
- Select Delete.
- Select Delete again to confirm deletion.
Clearing the Track Log
Clearing the track log removes old track lines from the map screen.
- From the Main menu, select Tracking.
- Select Clear.
- Select Clear again to confirm.
- Select an option:
- Reset Trip: Clears trip values and speeds.
- Reset All: Clears trip values, speeds, and odometer.
The track log will now be cleared.
NOTE: You may still see a percentage of the storage taken up on the tracking page after selecting clear. This is due to having routes on the device.
