Changing Bluetooth Settings on the Alpha XL
Bluetooth is enabled by default on the Alpha® XL dog tracking and navigation device. To disable or restore Bluetooth, or change disconnect prompts on the device follow the instructions below:
Disable Bluetooth
If Bluetooth is enabled you will have a Bluetooth icon in the status bar at the top left of the main screen.
- Select the Bluetooth icon or select the Phone icon in All Settings
- Select the settings icon (three lines) in the upper left
- Select Disable Bluetooth
Restore Bluetooth
- Select the All Settings (gear) icon in the lower right corner
- Select the Phone menu item
- Select Restore
Show or Delay Disconnect Prompt
- Select Show Disconnect Prompt (available if delayed) or Delay Disconnect Prompt
