Older Garmin Mapping with Newer Garmin Outdoor Handhelds
The systems in newer Garmin Outdoor handheld devices have been updated and map configurations have also been improved. As such, third-party maps and some older Garmin maps are not compatible with these newer devices.
Receiving a "Cannot Authenticate Maps" error message on the handheld may indicate that you are using an incompatible map.
NOTE: This article applies to Garmin mapping only. We do not test third-party mapping and therefore cannot guarantee or assist in its functionality with our devices.
How to Resolve
Check the following article to ensure there is not another cause for this error: "Cannot Authenticate Maps" Error Message on an Outdoor Handheld
If the error persists, visit our website to confirm the compatibility of your handheld and the map:
- Go to Garmin.com.
- Click the magnifying glass in the top right corner of the page.
- Use the Search garmin.com field and input the map name (ie. TOPO Canada).
- Press Enter or Return on your keyboard to perform the search.
- Select the map from the results.
NOTE: If your map is not found in the results, the map is too old and a different map is needed. For assistance selecting a map, see - Choosing and Purchasing a Map for your Outdoor Handheld or Watch - Scroll down the page and select Compatible Devices.
- If your device is not listed and you had just purchased the map, contact the retailer to return it.
