Bushido Smart Trainer LED Lights and Error Codes
The Bushido Smart trainer features lights that signify the amount of resistance that is being applied during your workout. These lights are located to the right of the roller when looking at the trainer from the top down or from behind.
Green arrow pointing to the lights glowing green
 Green (least resistance)
Orange arrow pointing to the lights glowing orange
 Orange
Red arrow pointing to the lights glowing red
 Red (most resistance)
Flashing LED While Riding
The flashing light is related to the cadence you are riding. The faster you pedal the faster this flash will occur.
Error Codes
One or All Red Lights as you spin:
If you start to spin up on the bike and only one or all red LED light appears on the trainer, this indicates and issue within the electronics of the trainer.
No Lights As You Spin:
No lights can mean that the brake assembly has become separated. As you can see in the left image below, the outside casing on the side where the LED lights are visible has a gap. Use the palm of your hand to close the gap by pressing or popping the outer casing so that it looks like the right side image. If issues persist, contact Product Support for further assistance.
 Separation example on the left and correct seating on the right
IMPORTANT: Close the gap using the palm of your hand in order for the casing to look like the image on the right.
