Garmin Panoptix Transducer not Recognized by Connected Chartplotter
If a Panoptix™ transducer is not being recognized by the chartplotter, use the following troubleshooting steps:
Check that the transducer is wired to power correctly. Try a standalone 12-volt battery if using a fuse block/bus bar. Check the fuse to see if it is blown
Check that the transducer's Ethernet plug is plugged into one of the marine network ports on the chartplotter, try a different network port on the chartplotter (if available
Check that the software is up to date on the chartplotter. Marine device software updates can be accessed here
Check that the chartplotter is compatible with the Panoptix. For a list of compatible chartplotters, see below:
Panoptix™ PS21-TM/TR transducer
echoMAP™ Chirp 7x chartplotters | echoMAP™ Chirp 9x chartplotters
ECHOMAP™ Plus 7x chartplotters | ECHOMAP™ Plus 9x chartplotters
ECHOMAP™ UHD 7x chartplotters | ECHOMAP™ UHD 9x chartplotters
GPSMAP® 7x1 chartplotters
GPSMAP® 7x2 chartplotters | GPSMAP® 9x2 chartplotters
GPSMAP® 7x3 chartplotters | GPSMAP® 9x3chartplotters
GPSMAP® 8x0 chartplotters | GPSMAP® 10x0 chartplotters
GPSMAP® 10x2 | GPSMAP® 12x2 chartplotters | GPSMAP® 12x3 chartplotters
GPSMAP® 74xx chartplotters | GPSMAP® 76xx chartplotters
GPSMAP® 84xx chartplotters | GPSMAP® 86xx chartplotters | GPSMAP® 87xx chartplotters
Panoptix™ PS22-TR transducer
ECHOMAP™ UHD 7x chartplotters |ECHOMAP™ UHD 9x chartplotters
ECHOMAP™ Ultra chartplotters
GPSMAP® 7x3 chartplotters | GPSMAP® 9x3 chartplotters
GPSMAP® 10x2 chartplotters | GPSMAP® 12x2 Touch, Plus chartplotters
Panoptix™ PS30 transducer
ECHOMAP™ Plus 7x chartplotters | echoMAP™ Plus 9x chartplotters
ECHOMAP™ UHD 7x chartplotters | echoMAP™ UHD 9x chartplotters
Panoptix™ PS31 transducer
GPSMAP® 10x2 chartplotters |GPSMAP® 12x2 Touch, Plus chartplotters
Panoptix™ PS51 transducer
GPSMAP® 8x0 chartplotters |GPSMAP® 10x0 chartplotters
GPSMAP® 10x2 chartplotters | GPSMAP® 12x2, Touch, Plus chartplotters
GPSMAP® 74xx chartplotters | GPSMAP® 76xx Schartplotters
GPSMAP® 84xx chartplotters | GPSMAP® 85xx chartplotters | GPSMAP® 86xx chartplotters | GPSMAP® 87xx Series chartplotters
Panoptix™ PS60 transducer
Panoptix™ LVS12 transducer
LiveScope™ LVS32 transducer
If the chartplotter still does not recognize the Panoptix transducer, then the transducer would need to be replaced. Contact Product Support to replace the transducer.
