Pin Management with Auto-Calibration for the Xero A1i PRO
The Xero A1I PRO prompts you to validate the pin stack after auto-calibration. If you choose to skip validation during setup, you can validate the pin stack later through the arrow profile's settings or re-validate a pin stack that has been previously validated.
You can also manually calibrate the ranges in your arrow profile. Manually calibrating ranges from an auto-calibrated pin stack removes the validation option from the arrow profile and turns the profile into a manual profile. You can recreate the original profile with auto-calibration, if necessary.
  • By choosing Arrow Profile and selecting an Arrow Profile, the Validate Pin Stack or Validated Pin Stack options become available.
  • If the Validation step is skipped for any reason, the Validate Pin Stack menu option will allow for completion of this process
NOTE: If a calibrated range is added, the Xero A1i PRO removes any auto-calibration ranges within 5 yards of the newly calibrated range.
Related
