Getting Started with the Delta SE
The Delta® SE remote training system allows you to train up to 2 dogs with a 1/2 mile line-of-sight range. A quick turn dial gives positive clicks when changing between 10 stimulation levels. The 3 button control provides tone, vibrate, continuous stimulation, and momentary stimulation training features.
IMPORTANT: The handheld device must be charged before first use to remove it from low-power ship mode. If not charged, the handheld and dog device will not work together properly. It is highly recommended both the handheld and dog collar are charged fully before first use.
Charging the Delta SE Handheld
Charging your Delta SE handheld can take around 2-3 hours and uses a USB-C charging cable.
Delta SE Charging Port
Charging the Collars
A solid red LED indicates that the collar is charging.
A solid green LED indicates that the collar is fully charged.
Button and Key Functions
The 3 keys on the front of the device are indicated by letter corresponding with what training function the key provides.
Delta SE Front
  • Momentary stimulation is indicated by the M key
  • Continuous stimulation is indicated by the C key.
    • Continuous stimulation will last for approximately 8 seconds while the button is held down.
  • Tone is indicated by the T key
Using the Training Dial
The training dial has 10 levels of stimulation. Each level of stimulation can be applied with either a press of the M (Momentary) button for a momentary correction or the C (Continuous) button for a continuous stimulation. A continuous stimulation lasts up to 8 seconds.
The training dial also has a feature for a Vibrate indicated by the letter V on the dial. To use the vibrate feature you will turn the dial to the V and then press either the C or M button to provide a vibrate correction on the collar. Either button will provide a vibrate correction and both corrections will last approximately 8 seconds while the button is held down.
Pairing
After your handheld and collars are fully charged you can pair them.
Preparing the Devices for Pairing
  1. Use the side switch in either the up or down position to pair your collar the handheld and set the training dial to a number.
    Delta SE Slide for pairing
  2. Power On the dog collar.
Pairing the Delta SE Handheld to the Dog Collar
  1. Press and hold the Power button on the dog collar.
  2. At the same time press and hold any training key on the handheld.
  3. Continue to hold the buttons until the dog collar turns off.
Testing the Connection
  1. Power On the dog collar.
  2. Press T (Tone) on the handheld.
  3. The collar should respond and give a tone.
Pairing an Additional Collar
Pairing the Delta SE Handheld to a Delta Sport™ XC/Delta XC Dog Device
  1. After your handheld and collars are fully charged you can pair them.
  2. Use the side switch by sliding it either up or down to pair your collar to the handheld.
  3. Set the intensity level to a number.
  4. Power on the dog collar.
  1. Press and hold the Power on the dog collar.
Pairing the Delta SE Handheld to a PT 10/PT 6 Dog Device
  4. Ensure the dog collar is turned off.
  1. Press and hold the Power button on the dog collar until the LED turns yellow
    • Continue to hold the Power button as the collar LED transitions from green to blue to yellow.
  2. When the LED turns yellow, press any training key on the handheld.
  3. The collar will give a melodic series of tones.
  4. Release both buttons at the same time.
Device Registration and Maintenance
Garmin Express is used to register your handheld, it can also be used for software updates to the Delta SE handheld.
Garmin Express
You can use Garmin Express™ program and update the software on your handheld anytime if an update is available.
  • Garmin Express program requires the use of a computer using the Windows or Mac operating system and will require internet access to download any available updates
  • If Garmin Express software is not already installed download it and install on your computer
  • If you need more detailed instructions follow the link below
Installing Software Update to the Delta SE Handheld
