Helpful Alerts on the Garmin babyCam
When your compatible navigation device loses external power, a helpful on-screen alert can be enabled to remind you to check for rear seat passengers.
To Enable/Disable Helpful Alerts:
  1. Touch Settings
  2. Touch babyCam
  3. Select paired camera
If there is no checkmark next to the "Check Seat Reminder", touch the box to add a check. This will enable the reminder on the device. If you do not want to receive the reminder, touch the box to remove the check.
