GPSMAP 66i Main Menu Options
The main menu of the GPSMAP® 66i outdoor handheld contains all the information you need to operate your device. To access the main menu, press MENU twice from any screen. The information below explains what settings and features are available for each of the options in the menu.
NOTE: Some options are not present in the menu by default or may not be available if the software on the handheld is not up to date. To install software updates, see - Updating the Software on Your GPSMAP 66i. To move, add, or delete items in the main menu, see - GPSMAP 66i: Customizing the Main Menu.
GPSMAP 66i Active Route Active Route
While navigating a route, this option allows you to view the active route.
GPSMAP 66i Active Weather Active Weather
While the handheld is connected to your smartphone or to a Wi‑Fi network, it can receive detailed weather information from the internet. For more details, see - Active Weather Feature on Outdoor Handhelds.
GPSMAP 66i Adventures Adventures
Allows you to access Garmin Adventures that have been transferred to the handheld. For more details, see - Completing a Garmin Adventure on a Handheld Device.
GPSMAP 66i Alarm Clock Alarm Clock
Sets an audible alarm that can power on the handheld and alert you at a specified time.
Press MENU for additional options:
Timer/Alarm Clock
Allows you to toggle between setting a countdown timer or an alarm clock.
Time Setup
Allows you to change the Time Format and Time Zone settings of the handheld.
GPSMAP 66i Altimeter Altimeter
By default, this displays the elevation over the distance traveled. Use the directional pad to select any point on the plot to view details about that point.
Reset
Resets the altimeter data, including waypoint, track, and trip data.
Altimeter Setup
Access additional altimeter settings. For more details, see - GPSMAP 66i: Altimeter Settings.
Adjust Zoom Ranges
Adjusts the zoom ranges shown on the altimeter page.
Change Data Fields
Allows you to customize the altimeter data fields.
Restore Defaults
Restores the altimeter to factory default settings.
GPSMAP 66i Area Calculation Area Calculation
Allows you to calculate the size of an area by walking around the perimeter of the area.
GPSMAP 66i BirdsEye Direct BirdsEye Direct
Allows you to download high-resolution satellite imagery directly to the handheld when it is connected to a Wi‑Fi network. For more details, see - Download, View, or Delete BirdsEye Direct Satellite Imagery on a GPSMAP 66 or 86 Series.
GPSMAP 66i Calculator Calculator
Displays a calculator.
Scientific/Standard
Toggle between scientific and standard calculator options.
Radians/Degrees
Toggle between radians and degrees modes for interpreting angle values.
GPSMAP 66i Calendar Calendar
Displays a calendar. Use the directional pad to select different dates and view the activities, tracks, or waypoints that were recorded on the selected date.
Use Current Date
Defaults to view the current date on the calendar.
View Sun and Moon
View the sunrise, sunset, moonrise, and moonset times for the selected date along with the moon phase, based on your current location.
View Hunt and Fish
View the predicted best times for hunting and fishing at your current location for the selected date.
GPSMAP 66i Collections Manager Collections Manager
Displays collections synced from your Garmin Explore™ account. For more details, see - Collections Manager on the GPSMAP 66/86.
GPSMAP 66i Compass Compass
Displays a compass to aid with navigation.
Sight 'N Go
Allows you to point the device at an object in the distance, and navigate using the object as a reference point (Navigating with Sight 'N Go).
Stop Navigation
Stops navigating the current route.
Change Dashboard
Changes the theme and information displayed on the dashboard.
Calibrate Compass
Allows you to calibrate the compass if you experience irregular compass behavior, for example, after moving long distances or after extreme temperature changes. For more details, see - GPSMAP 66i: Calibrating the Compass.
Heading Setup
Allows you to customize the compass heading settings. For more details, see - GPSMAP 66i: Heading Settings.
Change Data Fields
Customizes the compass data fields.
Restore Defaults
Restores the compass to factory default settings.
GPSMAP 66i Connect IQ Connect IQ™
Displays a list of installed Connect IQ apps. For more details, see - GPSMAP 66i: Connect IQ Features.
GPSMAP 66i Course Planner Course Planner
Displays a list of saved courses and allows you to create new courses. For more details, see - Using Course Planner on a GPSMAP 66 or 86 Series.
GPSMAP 66i Flashlight Flashlight
Turns on the flashlight. For more details, see - GPSMAP 66i: Using the Flashlight.
GPSMAP 66i Geocaching Geocaching
Displays a list of downloaded geocaches. For more details, see - Live Geocaching on the GPSMAP 66/86 Series.
GPSMAP 66i Hunt and Fish Hunt and Fish
Displays a calendar with the predicted best dates and times for hunting and fishing at your current location (see Hunt/Fish Prediction Theory). Use the directional pad to select a different date from the calendar.
Use Current Date
New Location
Allows you to change the location for which predicted best dates and times for hunting and fishing are provided.
GPSMAP 66i inReach Activation inReach® Activation
Use this option to activate the handheld on an inReach satellite subscription in order to use inReach features. For more details, see - How to Activate a GPSMAP 66i/86i/86sci.
GPSMAP 66i inReach Weather inReach® Weather
NOTE: Requires an active inReach subscription.
Allows you to request basic, premium, or marine weather forecasts using your inReach subscription. For more details, see - Requesting Weather Forecasts With the GPSMAP 66i/86i/86sci.
GPSMAP 66i Man Overboard Man Overboard
Allows you to mark a waypoint while automatically starting direct-routing navigation to the location. For more details, see - Using Man Overboard (MOB) on a GPSMAP Series Outdoor Handheld.
GPSMAP 66i Map Map
Select this option to view the map.
GPSMAP 66i Messages Messages
Allows the user to send a check-in ( formerly known as preset) or custom text message using the Iridium satellite network and view received messages.
Message Setup
The following options are available within the Message Setup:
Ring Until Read
Sets the device to ring until you read a new message. This feature is helpful if you are in a noisy environment.
Notifications
Alerts you to incoming inReach messages.
Show on Map
Sets message locations to display on the map.
GPSMAP 66i Notifications Notifications
View notifications for incoming calls, texts, social network updates, and more from your smartphone when it is connected and in range of the handheld.
GPSMAP 66i Photo Viewer Photo Viewer
Displays photos that have been transferred to the handheld.
GPSMAP 66i Profile Change Profile Change
Allows you to change the device profile to customize your settings and data fields for a particular activity or trip. For more details, see - GPSMAP 66i: Profiles.
GPSMAP 66i Proximity Alarms Proximity Alarms
Allows you to create alarms that will sound when you are within range of particular locations.
Enable/Disable All Alarms
Allows you to quickly turn all proximity alarms on or off.
Change Units
Changes the radius units used.
Alarm Tones Setup
Allows you to enable, disable, and customize the alarm tones.
GPSMAP 66i Recorded Activities Recorded Activities
Displays your current activity and a list of recorded activities. For more details, see GPSMAP 66i: Recordings.
GPSMAP 66i Recording Controls Recording Controls
Allows you to view details about the current activity and control the current activity recording. For more details, see - GPSMAP 66i: Viewing the Current Activity.
GPSMAP 66i Route Planner Route Planner
Displays a list of saved routes and allows you to create new routes. For more details, see - GPSMAP 66i: Creating a Route.
GPSMAP 66i Satellite Satellite
Displays your current GPS satellite information.
Use With GPS On
Allows you to turn the GPS on if it is currently disabled. If GPS is already enabled, this option will not be present.
Track Up
Indicates whether satellites are shown with rings oriented with north toward the top of the screen or oriented with your current track toward the top of the screen.
Single Color/Multicolor
Allows you to select whether the satellite page is displayed in multicolor or single color.
Set Location On Map
Allows you to mark your current location on the map. You can use this location to create routes or search for saved locations.
AutoLocate Position
Calculates your GPS position using the Garmin AutoLocate feature. This feature can help to resolve satellite acquisition issues.
Satellite Setup
Allows you to set the satellite system system to GPS, GPS+GALILEO, or Demo Mode (Off). You can also enable/disable WAAS/EGNOS from these settings.
GPSMAP 66i Saved Tracks Saved Tracks
Displays a list of saved tracks. For more details, see - GPSMAP 66i: Creating a Track from a Saved Activity.
GPSMAP 66i Setup Setup
Allows you to access additional settings for customizing the handheld. For more details, see - GPSMAP 66i: Setup Menu.
GPSMAP 66i Share Wirelessly Share Wirelessly
Allows you to send and receive data wirelessly with another compatible Garmin device using ANT+ technology. You can share waypoints, geocaches, routes, tracks, and more.
GPSMAP 66i Sight N Go Sight 'N Go
Allows you to point the device at an object in the distance, and navigate using the object as a reference point. For more details, see - GPSMAP 66i: Navigating with Sight 'N Go.
GPSMAP 66i SOS SOS
Allows you to initiate an SOS rescue. This sends a message to Garmin Response™ Center, and they notify the appropriate emergency responders of your situation. You can communicate with Garmin Response center during your emergency while you wait for help to arrive. You should only use the SOS function in a real emergency situation.
GPSMAP 66i Stopwatch Stopwatch
Allows you to use a timer, mark a lap, and time laps.
Press MENU to access Enable Activ. Sync if you wish to sync the stopwatch with the current activity recording.
GPSMAP 66i Sun and Moon Sun and Moon
Displays a calendar with sunrise and sunset times, along with the moon phase, based on your current location. Use the directional pad to select a different date from the calendar.
Use Current Date
Show Position in Sky
Display sun and moon visibility from your current location based on the selected date and time.
New Location
Allows you to change the location for which sunrise and sunset times are provided.
GPSMAP 66i Tracking Tracking
NOTE: Requires an active inReach subscription plan. With the Safety plan, there is an additional cost per send/track point (varies by currency) when tracking is enabled. For more details, see - inReach Subscription Plan Options and Feature Information.
Allows you to record track points and transmit them over the Iridium satellite network at the specified moving interval. Track points appear on the Garmin Explore™ website and either the LiveTrack™ tracking page or MapShare™ tracking page (depending on your account settings).
Press MENU to access Tracking Setup. For more details, see - Track Settings Explained on the GPSMAP 66i/86i/86sci.
GPSMAP 66i Trip Computer Trip Computer
The trip computer displays your current speed, average speed, trip odometer, and other helpful statistics. You can customize the trip computer layout, dashboard, and data fields.
Reset
Resets all the trip computer values to zero. For accurate information, reset the trip information before beginning a trip.
Change Data Fields
Customizes the trip computer data fields.
Change Dashboard
NOTE: Your customized settings are remembered by the dashboard. Your settings are not lost when you change profiles.
Insert Page
Inserts an additional page of customizable data fields.
TIP: You can use the arrow keys to scroll through the pages.
Remove Page
Removes an additional page of customizable data fields.
More Data
Adds additional data fields to the trip computer.
Less Data
Removes data fields from the trip computer.
Restore Defaults
Restores the trip computer to factory default settings.
GPSMAP 66i VIRB Remote VIRB® Remote
Provides camera controls when you have a Garmin VIRB camera connected with the GPSMAP 66i.
GPSMAP 66i Waypoint Averaging Waypoint Averaging
Allows you to refine a waypoint location for more accuracy. For more details, see - Waypoint Averaging Information for Outdoor Handhelds.
Press MENU for additional search, filter, and sort options.
GPSMAP 66i Waypoint Manager Waypoint Manager
Displays all waypoints saved to the handheld. For more details, see - GPSMAP 66i: Waypoints.
GPSMAP 66i Where To Where To?
Opens the search menu to start navigating to a destination.
GPSMAP 66i XERO Locations XERO® Locations
Displays laser location information when you have a Xero bow sight paired with your GPSMAP 66i. For more details, see - Sending Xero Locations to a Garmin Compatible Handheld.
