Editing Check-In Contacts in the Garmin Messenger App
Check-in messages are a convenient way to send messages to specific group of friends and family. There are three check-in messages to choose from:
  • Check Mark I'm checking in, everything is okay.
  • Triangle I'm starting my trip.
  • Square I'm ending my trip.
You can customize the recipient list of your check-in messages, but you cannot customize what the check-in messages say. Check-in messages will include your location if available.
Editing Your Check-in Contacts
NOTE: To edit your check-in contacts, your phone must have Wi-Fi or mobile data available so the changes can be saved to your online account. It is best to edit check-in contacts before leaving on a trip. Some older inReach® accounts may instead show Presets with an option to Set Up Check-in (see Differences Between Preset, Check-in, and Quick Text Messages for more details).
  1. Ensure your inReach compatible device is powered on and paired with the Garmin Messenger™ app.
  2. In the Garmin Messenger app, select Device.
  3. Select Check-In.
  4. Select Edit Check-in Contacts to customize the recipient list of your check-in messages:
  5. Select an option:
    • Touch the field next to To: to manually enter SMS numbers, email addresses, or inReach addresses. You can also start typing the name of a saved contact, then select the contact from the list of results.
      -OR-
    • Select Plus Symbol, then select System Contacts, inReach Contacts, or MapShare™ to add contacts that are already saved to your phone or inReach account.
      NOTE: Selecting MapShare as a contact allows the message to appear on your MapShare page. This option only appears if you have enabled the MapShare feature.
  6. Select SAVE.
Related
