Using Glances on a Compatible Garmin Watch
Glances allow you to see three widgets at a time while scrolling through your compatible Garmin® watch. This allows you to compare information between widgets at a glance. When you select a glance it will bring you to the detailed view.
Example of Some Widget glances on a Garmin watch
Watches Compatible With Glances
NOTE: If you do not see Glances on your device you may need to update the software for your watch. Refer to your owner's manual for steps on updating the software.
  • Approach® S44
  • Approach® S50
  • Approach® S70  | Approach® S70 - TaylorMade® Edition
  • D2™ Air X10
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
  • Descent™ G2
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
  • Descent™ Mk3 | Descent™ Mk3i | Descent™ Mk3i
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition 47 mm| epix™ (Gen 2) - Sapphire Edition 47 mm | epix™ (Gen 2) - Porsche Edition
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 55
  • Forerunner® 165 | Forerunner® 165 Music
  • Forerunner® 255 | Forerunner® 255 Music | Forerunner® 255S | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 745
  • Forerunner® 945 | Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar
  • Instinct® E
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • Venu® 2 | Venu® 2S
  • Venu® 2 Plus
  • Venu® 3 | Venu® 3S
  • vívoactive® 5
  • vívoactive® 6
Customize My Glances
Customizing the glances on most watches can be done through the Garmin Connect™ app using the steps below. Select models will allow you to make these changes directly on the watch. For details on how to customize your glances through your watch settings please see your owner's manual
Add a Glance
  1. Open the Garmin Connect app.
  2. Open the menu by selecting More (bottom right).
  3. Select Garmin Devices.
  4. Select the name of your Garmin watch.
  5. Select Appearance.
  6. Select Glances or Widgets.
  7. Depending on your device, you may need to select Edit.
  8. Scroll down to the Available or Not Installed section.
  9. Depending on your device, select Blue plus sign to add a glance. Or select a widget and select Install.
  10. Return to the devices page and sync your watch.
Remove a Glance
  8. Depending on your device, select Red Minus Sign to remove the glance. Or select a widget and select Uninstall.
  9. Return to the devices page and sync your watch.
Rearrange the Glances
  6. Select Glances.
  7. Locate the glance you want to move.
  8. Select 3 horizontal lines stacked vertically and drag to the new position.
