Venu X1 Battery Life Assumptions
The battery life of your Garmin watch may be affected by how you use the watch. The information in the tables below is presented to help outline the conditions used to determine the estimated battery life specifications. Usage beyond what is listed below may result in reduced battery life. The information presented below is a reference-only guide for general use of the Venu® X1 watch.
The following usage assumptions were used to determine the estimated battery life for the Venu X1. Unless otherwise stated, all default software settings and configurations are assumed for battery life specifications.
Venu X1 Smartwatch Mode - Default Display Configuration
Notifications per Day50
Number of Interactions per Day32
Device-Generated Alerts per Day (Move or Goal Alerts)10
Hours per Day Outside of Bluetooth Range of Phone1
Display Brightness & TimeoutDefault Settings
Watch Face¹Default
Number of Gestures per Day750
Pulse Ox ModeDisabled by Default
Number of Minutes of Music Streaming0
Number of Timed Activities0
Battery LifeUp to 8 days
Venu X1 Smartwatch Mode - Display Always On Mode
Average Number of Hours Spent Outside25
Watch FaceDefault
Average Number of Hours per Day Sleep38
Display TimeoutAlways On
Battery LifeUp to 2 days
Venu X1 - Activity Mode
Number of Interactions per Hour10
Minutes of Interaction Post-Activity1
Number of Gestures per Hour25
Number of Alerts per Hour 9
Assumed Temperature Range for Battery Life Specifications10C – 40C
GPS-Only Mode without Music Battery Life4Up to 16 hours
All Systems (Default) Mode without Music Battery Life4
Up to 14 hours
GPS-Only Mode with Music Battery Life4Up to 7 hours
All Systems (Default) Mode with Music Battery Life4Up to 7 hours
1 The “default” watch face is the watch face present on the device when it is taken out of the box. The Venu X1 product is designed to work with a variety of native watch faces as well as compatible Connect IQ watch faces. The usage of watch faces other than the default watch face may impact the battery life experienced in smartwatch mode.
2 This device utilizes an ambient light sensor to automatically adjust the display brightness to an acceptable level depending upon the level of ambient light. Using the device outdoors in bright environments may reduce battery life.
3 The average number of hours per day of sleep is determined by the user-configured bed and wake times (a "sleep period"), not the number of hours the user actually sleeps. During this sleep period, the device's display is turned off. As a result, setting a shorter sleep period may decrease the battery life experienced in display always on mode.
4 The use of the Flashlight or Flashlight Strobe feature will have a significant impact on battery life. Use of this feature is not factored into the battery life estimates listed above.
