D2 Mach 1 Pro Battery Life Assumptions
The battery life of your Garmin® watch may be affected by how you use the watch. The information presented below is presented as a general guide for reference only on the D2™ Mach 1 Pro watch. All default software settings and configurations are assumed for the battery life specifications.
Battery Life Specifications
Default Settings (Display Always-On)
    • Smartwatch Mode: Up to 10 days
    • GPS Only: Up to 58 hours
    • All Satellite Systems: Up to 48 hours
    • All Satellite Systems + Multi-band: Up to 30 hours
    • All Satellite Systems + Music: Up to 17 hours
Prolonged Battery Life (Gesture Enabled)
NOTE: Refer to Changing the Screen Settings for steps on enabling Wrist Gesture.
    • Smartwatch Mode: Up to 25 days
    • Battery Saver Watch Mode: Up to 41 days
    • GPS Only: Up to 82 hours
    • All Satellite Systems: Up to 62 hours
    • All Satellite Systems + Multi-band: Up to 38 hours
    • Max Battery GPS: Up to 145 hours
    • Expedition GPS: Up to 27 days
    • Fly Activity (GPS + SpO2) : Up to 46 hours
Usage Factors That Impact Battery Life
  • The D2 Mach 1 Pro watch uses an ambient light sensor to automatically adjust the display brightness to an acceptable level depending upon the level of ambient light. Using the watch outdoors in bright environments may reduce battery life.
  • Changes to the default display settings can significantly impact battery life. Higher screen usage will generally result in less battery life.
Tips for Maximizing Battery Life
