MARQ Series Barometric Altimeter Calibration Options
The barometric altimeter on the MARQ series uses GPS elevation and/or uses DEM (Digital Elevation Map) data to provide elevation data dependent on which mode the watch is using. With proper calibration the watch can achieve accuracy of +/-50 feet. Use the information below to determine which calibration options are best for you.
Manual Calibration Options
If the altimeter of MARQ series watch is displaying elevation that is more that +/-50 feet off, it should be calibrated. Below are the options for calibrating the altimeter.
  • Known Elevation (Yes) - Use this option to calibrate if you know the current elevation. This option offers the most accurate calibration.
  • Use DEM - The watch will locate your position through GPS and use the DEM data to get an elevation reading from the map.
  • Use GPS - This mode will determine your elevation through GPS triangulation. Elevation calibrated through GPS is accurate to +/-400 feet.
Select Calibrating the Altimeter to learn more.
Calibrating the altimeter should always be done outside with a clear view of the sky.
  1. Hold Up to enter the Main Menu
  2. Scroll to Settings and select Sensors & Accessories
  3. Select Altimeter
  4. Select Calibrate
  5. Select and option and follow onscreen prompts
Auto Calibration Options During Activity
These settings allow you to control how calibration of the altimeter happens while you are in an activity.
  • Continuous Mode - During activities the watch uses DEM mapping data, and GPS elevation to offset any altimeter drift due to pressure changes caused by a weather event during an activity. Continuous Mode will allow the watch to calibrate altitude throughout the activity.
  • At Start - The watch will use DEM data and GPS location to calibrate the altimeter at the beginning of the activity. It will not calibrate again during the activity.
  • Off - The watch will not perform any calibration during or at the start of the activity.
Note: For more information on how barometric pressure effects the altimeter sensor, see  Related Content
Setting Auto Calibration
  3. Select Altimeter
  4. Select Auto Cal.
  5. Select During Activity
  6. Select an option
Auto Calibration Not During Activity
These settings allow you to control how calibration of the altimeter happens while the fenix 5 Plus series is being
  • On - The watch will calibrate the altimeter anytime GPS is acquired by using DEM and your location.
  • Off - The watch will not automatically calibrate the altimeter, and manual calibration will need to be used.
  3. Select Altimeter
  4. Select Auto Cal.
  5. Select No During Activity
  6. Toggle On or Off
Related
