Pairing an inReach Messenger Plus With the Garmin Messenger App
NOTE: This article is intended for users who have already activated an inReach® subscription for their inReach Messenger Plus. If you have not yet activated an inReach subscription for the device, see - Pairing Your Phone and Activating an inReach Messenger Plus.
The Garmin Messenger™ app is an Android and iOS mobile application that optimizes inReach® messaging to use the cellular connection of your compatible smartphone when it is available, then switches to 100% global Iridium® satellite connection with a compatible inReach device when you go beyond available cellular coverage range. It also allows you to control and customize certain functions and settings for the connected inReach device.
When you first set up the Garmin Messenger app, you are prompted to verify your mobile phone number on the mobile phone that will be used. From that point on, any inReach messages sent to your phone number will be routed to the Garmin Messenger app instead of your phone's default text messaging app.
The inReach Messenger Plus can be paired with one smartphone at a time.
1. Setting up the Garmin Messenger App
- Install and open the Garmin Messenger™ app.
Allow any app permissions when prompted.
Tap Get Started.
Select Create Account, then enter your name, email, and a password and select Next.
NOTE: If you already have a Garmin account or have previously used other Garmin apps such as Garmin Connect™ or Garmin Explore™ you can select Sign In (or Continue as ['username'], if prompted).
Follow the prompts to verify your mobile phone number, confirm you have read the End User License Agreement, then select Next.
NOTE: If you use a VPN on your phone, it may need to be temporarily disabled during this step as it may prevent the app from being able to send the verification code to your mobile phone number. VPN can be reenabled after you have finished setting up the app.
Enter the verification code sent to your mobile phone number.
Select Next and follow the prompts to enable permissions.
2. Pairing the inReach Messenger Plus
In the Garmin Messenger app, select the profile icon or
in the top left.
Select Add Device (or Devices > Add Device).
Enable pairing mode on the inReach Messenger Plus:
If necessary, press and hold OK to reach the home page.
Press
or
to scroll through the main menu and select SETTINGS
Select Phone
Select Pair Phone.
In the Garmin Messenger app, select Connect It and enter the 6 digit code from the inReach Messenger Plus when prompted.
